Error code on running Jupyter notebook - gpt-3.5-turbo
In the Jupyter Notebook, the openAI that is used is gpt-3.5-turbo is deprecated. I am getting this error. I tried various other models and they are not working.
Please suggest which model to use.
You’ll have to wait for the course to be updated to use a new model.
@lesly.zerna, is this on the timetable?
May I know when it might happen?
Thanks,
Kishore Babu Ch
That’s hard to say. DL.AI staff is probably not at work on the weekends.
You cannot resolve this by manually swapping model names in the notebook. The lab environment routes API calls through a platform proxy that only allows specific whitelisted endpoints, so unapproved model strings will return 404 or permission errors.
Because older model families are continuously retired by providers, the course maintainers have to update both the backend proxy and the lab code to the current active release.
Do not edit the model configuration cells manually. Once course staff deploys the fix:
  1. Save any personal notes by renaming your current notebook.
  2. Click Lab Help → Get Latest Version to pull the updated, working environment.
  3. Restart the kernel and run from the top.
We’re working on updating this week. I’ll keep you updated.
