L1_Router_Engine Notebook - Model has been deprecated
Hey team,
noticing another model deprecation in L1_Router_Engine for the course: Building Agentic RAG with Llamaindex
Getting the following error Code after trying to run the first Query Engine
Retrying llama_index.llms.openai.base.OpenAI._chat in 0.2668917181231596 seconds as it raised NotFoundError: Error code: 404 - {'error': {'message': 'The model `gpt-3.5-turbo` has been deprecated, learn more here: https://platform.openai.com/docs/deprecations', 'type': 'invalid_request_error', 'param': None, 'code': 'model_not_found'}}.
Retrying llama_index.llms.openai.base.OpenAI._chat in 1.361193232893352 seconds as it raised NotFoundError: Error code: 404 - {'error': {'message': 'The model `gpt-3.5-turbo` has been deprecated, learn more here: https://platform.openai.com/docs/deprecations', 'type': 'invalid_request_error', 'param': None, 'code': 'model_not_found'}}.
Retrying llama_index.llms.openai.base.OpenAI._chat in 0.057395592527235806 seconds as it raised NotFoundError: Error code: 404 - {'error': {'message': 'The model `gpt-3.5-turbo` has been deprecated, learn more here: https://platform.openai.com/docs/deprecations', 'type': 'invalid_request_error', 'param': None, 'code': 'model_not_found'}}.
Retrying llama_index.llms.openai.base.OpenAI._chat in 6.479215397467871 seconds as it raised NotFoundError: Error code: 404 - {'error': {'message': 'The model `gpt-3.5-turbo` has been deprecated, learn more here: https://platform.openai.com/docs/deprecations', 'type': 'invalid_request_error', 'param': None, 'code': 'model_not_found'}}.
Retrying llama_index.llms.openai.base.OpenAI._chat in 5.056465519975079 seconds as it raised NotFoundError: Error code: 404 - {'error': {'message': 'The model `gpt-3.5-turbo` has been deprecated, learn more here: https://platform.openai.com/docs/deprecations', 'type': 'invalid_request_error', 'param': None, 'code': 'model_not_found'}}.
NotFoundError                             Traceback (most recent call last)
Cell In[11], line 1
----> 1 response = query_engine.query("What is the summary of the document?")
      2 print(str(response))
File /usr/local/lib/python3.11/site-packages/llama_index/core/instrumentation/dispatcher.py:274, in Dispatcher.span.<locals>.wrapper(func, instance, args, kwargs)
    270 self.span_enter(
    271     id_=id_, bound_args=bound_args, instance=instance, parent_id=parent_id
    272 )
    273 try:
--> 274     result = func(*args, **kwargs)
    275 except BaseException as e:
    276     self.event(SpanDropEvent(span_id=id_, err_str=str(e)))
File /usr/local/lib/python3.11/site-packages/llama_index/core/base/base_query_engine.py:53, in BaseQueryEngine.query(self, str_or_query_bundle)
     51     if isinstance(str_or_query_bundle, str):
     52         str_or_query_bundle = QueryBundle(str_or_query_bundle)
---> 53     query_result = self._query(str_or_query_bundle)
     54 dispatch_event(QueryEndEvent())
     55 return query_result
File /usr/local/lib/python3.11/site-packages/llama_index/core/query_engine/router_query_engine.py:169, in RouterQueryEngine._query(self, query_bundle)
    165 def _query(self, query_bundle: QueryBundle) -> RESPONSE_TYPE:
    166     with self.callback_manager.event(
    167         CBEventType.QUERY, payload={EventPayload.QUERY_STR: query_bundle.query_str}
    168     ) as query_event:
--> 169         result = self._selector.select(self._metadatas, query_bundle)
    171         if len(result.inds) > 1:
    172             responses = []
File /usr/local/lib/python3.11/site-packages/llama_index/core/base/base_selector.py:87, in BaseSelector.select(self, choices, query)
     85 metadatas = [_wrap_choice(choice) for choice in choices]
     86 query_bundle = _wrap_query(query)
---> 87 return self._select(choices=metadatas, query=query_bundle)
File /usr/local/lib/python3.11/site-packages/llama_index/core/selectors/llm_selectors.py:109, in LLMSingleSelector._select(self, choices, query)
    106 choices_text = _build_choices_text(choices)
    108 # predict
--> 109 prediction = self._llm.predict(
    110     prompt=self._prompt,
    111     num_choices=len(choices),
    112     context_list=choices_text,
    113     query_str=query.query_str,
    114 )
    116 # parse output
    117 assert self._prompt.output_parser is not None
    272 )
    273 try:
File /usr/local/lib/python3.11/site-packages/llama_index/core/llms/llm.py:430, in LLM.predict(self, prompt, **prompt_args)
    428 if self.metadata.is_chat_model:
    429     messages = self._get_messages(prompt, **prompt_args)
--> 430     chat_response = self.chat(messages)
    431     output = chat_response.message.content or ""
    432 else:
File /usr/local/lib/python3.11/site-packages/llama_index/core/llms/callbacks.py:144, in llm_chat_callback.<locals>.wrap.<locals>.wrapped_llm_chat(_self, messages, **kwargs)
    128 dispatcher.event(
    129     LLMChatStartEvent(
    130         model_dict=_self.to_dict(),
    134     )
    135 )
    136 event_id = callback_manager.on_event_start(
    137     CBEventType.LLM,
    138     payload={
    142     },
    143 )
--> 144 f_return_val = f(_self, messages, **kwargs)
    146 if isinstance(f_return_val, Generator):
    147     # intercept the generator and add a callback to the end
    148     def wrapped_gen() -> ChatResponseGen:
File /usr/local/lib/python3.11/site-packages/llama_index/llms/openai/base.py:296, in OpenAI.chat(self, messages, **kwargs)
    294 else:
    295     chat_fn = completion_to_chat_decorator(self._complete)
--> 296 return chat_fn(messages, **kwargs)
File /usr/local/lib/python3.11/site-packages/tenacity/__init__.py:289, in BaseRetrying.wraps.<locals>.wrapped_f(*args, **kw)
    287 @functools.wraps(f)
    288 def wrapped_f(*args: t.Any, **kw: t.Any) -> t.Any:
--> 289     return self(f, *args, **kw)
File /usr/local/lib/python3.11/site-packages/tenacity/__init__.py:379, in Retrying.__call__(self, fn, *args, **kwargs)
    377 retry_state = RetryCallState(retry_object=self, fn=fn, args=args, kwargs=kwargs)
    378 while True:
--> 379     do = self.iter(retry_state=retry_state)
    380     if isinstance(do, DoAttempt):
    381         try:
File /usr/local/lib/python3.11/site-packages/tenacity/__init__.py:325, in BaseRetrying.iter(self, retry_state)
    323     retry_exc = self.retry_error_cls(fut)
    324     if self.reraise:
--> 325         raise retry_exc.reraise()
    326     raise retry_exc from fut.exception()
    328 if self.wait:
File /usr/local/lib/python3.11/site-packages/tenacity/__init__.py:158, in RetryError.reraise(self)
    156 def reraise(self) -> t.NoReturn:
    157     if self.last_attempt.failed:
--> 158         raise self.last_attempt.result()
    159     raise self
File /usr/local/lib/python3.11/concurrent/futures/_base.py:449, in Future.result(self, timeout)
    447     raise CancelledError()
    448 elif self._state == FINISHED:
--> 449     return self.__get_result()
    451 self._condition.wait(timeout)
    453 if self._state in [CANCELLED, CANCELLED_AND_NOTIFIED]:
File /usr/local/lib/python3.11/concurrent/futures/_base.py:401, in Future.__get_result(self)
    399 if self._exception:
    400     try:
--> 401         raise self._exception
    402     finally:
    403         # Break a reference cycle with the exception in self._exception
    404         self = None
File /usr/local/lib/python3.11/site-packages/tenacity/__init__.py:382, in Retrying.__call__(self, fn, *args, **kwargs)
    381     try:
--> 382         result = fn(*args, **kwargs)
    383     except BaseException:  # noqa: B902
    384         retry_state.set_exception(sys.exc_info())  # type: ignore[arg-type]
File /usr/local/lib/python3.11/site-packages/llama_index/llms/openai/base.py:362, in OpenAI._chat(self, messages, **kwargs)
    360 client = self._get_client()
    361 message_dicts = to_openai_message_dicts(messages)
--> 362 response = client.chat.completions.create(
    363     messages=message_dicts,
    364     stream=False,
    365     **self._get_model_kwargs(**kwargs),
    366 )
    367 openai_message = response.choices[0].message
    368 message = from_openai_message(openai_message)
File /usr/local/lib/python3.11/site-packages/openai/_utils/_utils.py:277, in required_args.<locals>.inner.<locals>.wrapper(*args, **kwargs)
    275             msg = f"Missing required argument: {quote(missing[0])}"
    276     raise TypeError(msg)
--> 277 return func(*args, **kwargs)
File /usr/local/lib/python3.11/site-packages/openai/resources/chat/completions.py:581, in Completions.create(self, messages, model, frequency_penalty, function_call, functions, logit_bias, logprobs, max_tokens, n, presence_penalty, response_format, seed, stop, stream, temperature, tool_choice, tools, top_logprobs, top_p, user, extra_headers, extra_query, extra_body, timeout)
    550 @required_args(["messages", "model"], ["messages", "model", "stream"])
    551 def create(
    552     self,
    579     timeout: float | httpx.Timeout | None | NotGiven = NOT_GIVEN,
    580 ) -> ChatCompletion | Stream[ChatCompletionChunk]:
--> 581     return self._post(
    582         "/chat/completions",
    583         body=maybe_transform(
    584             {
    585                 "messages": messages,
    586                 "model": model,
    587                 "frequency_penalty": frequency_penalty,
    588                 "function_call": function_call,
    589                 "functions": functions,
    590                 "logit_bias": logit_bias,
    591                 "logprobs": logprobs,
    592                 "max_tokens": max_tokens,
    593                 "n": n,
    594                 "presence_penalty": presence_penalty,
    595                 "response_format": response_format,
    596                 "seed": seed,
    597                 "stop": stop,
    598                 "stream": stream,
    599                 "temperature": temperature,
    600                 "tool_choice": tool_choice,
    601                 "tools": tools,
    602                 "top_logprobs": top_logprobs,
    603                 "top_p": top_p,
    604                 "user": user,
    605             },
    606             completion_create_params.CompletionCreateParams,
    607         ),
    608         options=make_request_options(
    609             extra_headers=extra_headers, extra_query=extra_query, extra_body=extra_body, timeout=timeout
    610         ),
    611         cast_to=ChatCompletion,
    612         stream=stream or False,
    613         stream_cls=Stream[ChatCompletionChunk],
    614     )
File /usr/local/lib/python3.11/site-packages/openai/_base_client.py:1232, in SyncAPIClient.post(self, path, cast_to, body, options, files, stream, stream_cls)
   1218 def post(
   1219     self,
   1220     path: str,
   1227     stream_cls: type[_StreamT] | None = None,
   1228 ) -> ResponseT | _StreamT:
   1229     opts = FinalRequestOptions.construct(
   1230         method="post", url=path, json_data=body, files=to_httpx_files(files), **options
   1231     )
-> 1232     return cast(ResponseT, self.request(cast_to, opts, stream=stream, stream_cls=stream_cls))
File /usr/local/lib/python3.11/site-packages/openai/_base_client.py:921, in SyncAPIClient.request(self, cast_to, options, remaining_retries, stream, stream_cls)
    912 def request(
    913     self,
    914     cast_to: Type[ResponseT],
    919     stream_cls: type[_StreamT] | None = None,
    920 ) -> ResponseT | _StreamT:
--> 921     return self._request(
    922         cast_to=cast_to,
    923         options=options,
    924         stream=stream,
    925         stream_cls=stream_cls,
    926         remaining_retries=remaining_retries,
    927     )
File /usr/local/lib/python3.11/site-packages/openai/_base_client.py:1012, in SyncAPIClient._request(self, cast_to, options, remaining_retries, stream, stream_cls)
   1009         err.response.read()
   1011     log.debug("Re-raising status error")
-> 1012     raise self._make_status_error_from_response(err.response) from None
   1014 return self._process_response(
   1015     cast_to=cast_to,
   1016     options=options,
   1019     stream_cls=stream_cls,
   1020 )
Can you please have a look into this.
Just adding, that this is actually happening throughout the course in all Notebooks.
@lesly.zerna, can you investigate this?
Thanks for flagging. I will totally take a look.
