here is the error I get:
WARNING:llama_index.embeddings.openai.utils:Retrying llama_index.embeddings.openai.base.get_embeddings in 0.4225984022196171 seconds as it raised APIConnectionError: Connection error..
LocalProtocolError Traceback (most recent call last)
/usr/local/lib/python3.10/dist-packages/httpx/_transports/default.py in map_httpcore_exceptions() 68 try: —> 69 yield 70 except Exception as exc:
60 frames
LocalProtocolError: Illegal header value b’Bearer ’
The above exception was the direct cause of the following exception:
APIConnectionError Traceback (most recent call last)
/usr/local/lib/python3.10/dist-packages/openai/_base_client.py in _request(self, cast_to, options, remaining_retries, stream, stream_cls) 984 985 log.debug(“Raising connection error”) → 986 raise APIConnectionError(request=request) from err 987 988 log.debug(
I cannot understand what goes wrong here. The summary_index works just fine. Any ideas?
